1 - 6 of 6 Posts
I am curious how everyone mounted there after-market amps and I wanted to see how yall made the wires clean.
Post pictures!
Also has anyone mounted there amp on the left wheel well?
you should mount it where it can't be seen. Cut the Styrofoam spacer around the spare tire and mount it there out of sight on either side.
There are enough options for super tiny amps that it should be easy.
I have a Rockford R600X5 which is pretty big, everyone has told me that there would be heat problems if I did that
I doubt you would have heat problems. I've seen amps mounted in much worse places and be fine.
You may have space issues though. I don't know how much room there is under there or the dimensions of the amp.
its a class D amp pretty efficient, and its not crazy powerful so it shouldn't make a lot of heat. should have plenty of breathing room under there.
1 - 6 of 6 Posts
