1 - 20 of 34 Posts
Sorry to see it all going back to stock!
I sent a PM for the Breedt STS.
15 TB Focus ST3
Right, literally need a skid plate. Glws!
2018 Focus ST3
GLWS. Wish I could pick up that skid plate but I'm on the other side of the country.
How did the turbo fin get chipped?
Discussion Starter · #6 · (Edited)
[/QUOTE]
I have no idea, never once did I run the car without an air filter.
Maybe when installing the BOV, some tiny debris fell in.
2016 Focus ST2
Would the skid plate work with a traction bar?
Does the hose coupler do anything or weigh less than the stock piece?
Weigh less, slightly so.
Looks much better and flows better than the accordian OEM junk
how did the turbo run with the chip?
Discussion Starter · #19 ·
Do the ST and the RS use the same skid plate?
Looks like it would fit, the subframe has the same holes and the layout is practically identical. The only thing I am not sure about, is where the skiplate mounts near the front, if the mounting points are also available on the RS. I took pictures of the mounting points, you can maybe see if the RS has holes there.
Ran strong, no issues, I had no idea it had a chip until removing and inspecting it.
Tempting. This is one of the big turbo set ups I really would consider.
1 - 20 of 34 Posts
