1 - 13 of 13 Posts
I have seen there are a few discussions on this but nothing clearly answered my questions I suppose. What do you have to do to the wiring if i want to add an aftermarket 8" in the stock enclosure. Do I need an 8" spacer ring and what sub will actually fit I've seen people throw up kicker comp S but I looked that speaker and it seems way to deep for the stock enclosure.
I have a Kicker CompRT 8" shallow sub in the stock box. Once you take the stock sub out of the box, you can rip the wires out and there will be holes to run new ones. The only modification you need to make the stock box for the new sub to fit is just break off a few of the plastic fins that line the back of the box and it fits perfectly.
[iurl="http://www.focusst.org/forum/attachment.php?attachmentid=303409&stc=1&d=1515863774"]
[/iurl]
Okay so that makes sense. Now when you say run new wiring what are you referring to ? I still have the stock amp is there a way to make this work using that and the existing wiring ?
Technically yes but the stock subwoofer uses 18g wiring and if you're going to be pushing more power, you'll probably want to use 16 or 14g wiring instead.
If he's using the stock amp, he won't be pushing any more power...
The important part is that what ever new sub you get, you have to get the same coil configuration as the OEM to properly use that amp.
Yeah a dual voice coil correct ? And I can cut and crimp connections to make the wiring work right ?
2017 Ford Focus ST
I was just about to start a similar thread, so I guess I will ask here. I have an ST1, is it possible to add an amp and subwoofer? I only have the basic ST1, no options electronics wise. My car is a 2017 year model.
Got it, I didn't see that OP was going to use the factory amp. Yeah, if you're just going to be using the factory amp, you can use the factory wiring but I would advise from getting a more expensive subwoofer since the stock amp can't really push out much power.
Discussion Starter · #10 ·
Okay cool I just want to bump it up a little I'm not looking for anything crazy. What subs would you recommend that fit in the enclosure ? Other than kicker
Yes, I added just a sub and amp and it worked perfectly
2017 Ford Focus ST
did you have to splice anything or are all the hookups already on the back of the unit in the dash?
You will also need to get a signal from behind the radio, there are no connectors back there, you will either need to use high level ins on an amp or install a line output device
1 - 13 of 13 Posts
