1 - 7 of 7 Posts
Advanced set up wizard DSR1. NOTE the screen shots are most likely incorrect I put them in as place holders as I figure out the best starting point for MY set up
NOT perfect but at least we have a starting point with some visuals
1. Once you connect your device using the perfect tune App select set up / then select set up device
then select the T harness or not = T harness is purchased separately for plug and play
Text Black Blue Font Sky
2. Once you connect your device using the perfect tune App select set up / then select set up device
then select the car /gear icon top right corner
3. Swipe the App from left to right and pick your speaker set up, below illustrates the stock speaker layout. Once done select "Ok got it"
bottom right hand corner
Text Font Screenshot Parallel Symmetry
4. If you have a bass control knob connected to your DSR1 then select that option. "Ok got it" NOT SURE THERE IS ONE YET
Text Font Sky Screenshot Line
5. Cross overs personal settings "Ok got it"
Text Font Technology Screenshot Electronic device
6. select the speaker icon on top left "red arrow"
Text Font Line Sky Technology
How hard was the install? Thinking about getting one myself. Would you recommend? A bit pricey.
It's one of the less expensive options actually. Super easy if its compatible with one of the t harnesses, if not, same as wiring in any other dsp
Sent from my SAMSUNG-SM-G935A using Tapatalk
A bit pricey.
LOL. Sorry. This comment made me laugh.
$250 for the level of ease of install/tuning/updating this device brings to the table is a bargain.
Now consider the SOUND that can be had after installing the DSR1. Some of you just don't understand the struggle in dealing with the craptastic Sony amp.
I say this all the time. Worth it? Yep. Twice over.
Pricey compared to what?
1)You cannot simply install an amp after the Sony amp.
2) Previous solutions to this are inferior.
The Sony amp controls sound shaping and time alignment and there is not a thing you can do about it. If you know what you are doing and by asking this question you obliviously don't understand how important this product is to remove the amp because even with the best DSP's on the market it still colors the sound.
$250 is an affordable price point, what pray-tell do you plan to purchase that is LESS and will be as effective?
Reactions: XRJoe and PHOKUS
pricey compared to what?
1)you cannot simply install an amp after the sony amp.
2) previous solutions to this are inferior.
The sony amp controls sound shaping and time alignment and there is not a thing you can do about it. If you know what you are doing and by asking this question you obliviously don't understand how important this product is to remove the amp because even with the best dsp's on the market it still colors the sound.
$250 is an affordable price point, what pray-tell do you plan to purchase that is less and will be as effective?
so much this.
if you have a sony system, I wouldn't even consider changing out anything more than just the speakers without using one. its pretty much the price of admission.
I'd say if you are doing a whole system, even with the best equipment you will not get better sound without one. you can easily get better sound with a DSR1 on less expensive equipment. other DSPs easily cost $600 or more and cant fully fix the problems that the OEM amp causes.
but please, we already have a couple of threads on why it is so important, how it works, and whats needed to do the install, lets try to keep this one clean and on topic of the more advanced tuning settings of the DSR1 and using one of those for the more basic questions (which may have already have been answered).
1 - 7 of 7 Posts
