So I had a 2015 ST and the rear passenger side door did not close properly. It was out of alignment so that you'd really have to slam it to make it sure it closed. This misalignment caused the door to rub through the weatherstripping and eventually I had it looked at and adjusted.
When it was at the body shop being adjusted, I basically heard a bunch of metal on metal hammering and 5 minutes later, it was done and the door lined up properly when closed.
Now I have a 2016 ST and.. it has the exact same issue. The rear passenger door doesn't close properly. It leads me to think this is a pretty common mis-alignment issue.
Question:
Anyone know how to properly adjust the rear door alignment so it closes properly?
I'm asking so I don't have to go to the dealership (which I am trying to avoid at all costs).
