2014 ST1 with 957XX milesI know nothing about tunes, tuning or Accessports, so I cannot be of assistance, but the way you presented the problem sounds like a riddle to me. I could be wrong, but I think you may get more helpful answers if you can provide information on the year and miles on the car, mods, tune you are using, as well as the circumstances surrounding the codes popping up rather than just having people ask you questions and take a shot in the dark.
The CHT (cylinder head temperature) and ECT (engine coolant temperature) sensors aren't correlating. It is putting the PCM into protection mode. You need to double check your coolant levels.Last night my '14 ST threw P1026 and P1450. I'm trying to find a fix to both of them and I haven't found any help.
If you know anything ask me some questions and I will get back to you
I have been monitoring the coolant level since the temps had started rising. In the reservoir it sits slightly below the min line even after I fill it every so often.The 1450 code merits Purge valve replacement. Common failure, accurate self-check.
The 1026 had several Definitions when i searched, but now that you mention coolant temp, it must be cylinder head temp sensor code. Without having enable criteria in front of me, it may be just a simple "engine overheat " code. In that case you need to stop driving the car and figure out why it's overheating before you melt the engine down. How's Your coolant level?
I check it about every week but only add more every month to 2 monthsHow often?
