1 - 3 of 3 Posts
Hey guys
I have a stage 3, I'm in the process of tuning through PD tuning and have one problem
Nearly every time, I flash a map and go for a drive I'll hit 18+ boost then the next day I start my car it will be hitting 9 boost, I'm also in the correct map... It's like every time I start my car I need to re flash it
Cheers in advance
What's you OAR at? And do you have the same issues when you flash one of the stock Cobb tunes? You may want to post a log when your only boosting low so some of the more qualified people on this forum can give you some educated advice.
Hey guys
Cheers in advance
Did you see the Cobb update to the V401 maps from the V400 http://www.focusst.org/forum/cobb-tuning/56713-2013-2014-map-slot-fix-update.html. Apparently with V400 you will randomly startup in the Eco slot instead of the Performance slot. When it happens check the map slot with the cruise control buttons.
1 - 3 of 3 Posts
