21 - 40 of 78 Posts
Yeah, but I think I'd be further from getting sanctioned, no?
With proper ground effects, I could create suction.
Oh I doubt it would ever be legal, but it is one efficient fan.
Discussion Starter #22
20 psi, 20 pounds by 3", squared. Right? 360 pounds of downfroce right at the front wheels. Something like that?
Well, I'm gonna see what it will produce, especially with the way I want to arrange it, and maybe it'll just keep the car nice and cool, and maybe I'll add a peak of high end on the right side of my rpms, right?
Discussion Starter #23
But first I need to find one that will fit...
Discussion Starter #24
Due to cost, but I am a poor boy, nobody love me. If I can make it work, I could make it painfully obvious that it SHOULD be legal.
so the benefits of a fan car are more downforce/cornering speed, right? Is there a certain track that you would be running thats going to see more benefits from that vs proper front/rear aero?
Discussion Starter #26
Adjustable rear downforce just became legal in F1, no? So, because the downforce is a plottable function, I can tune variable downforce devices to adjust to the fans.
Discussion Starter #27
@rambleon84 , to answer your question, theoretically, anytime the front wheels spin and need more traction, the rpms spin the fan and suck the car back down.
Discussion Starter #28
LoL, patent pending.
Keep in mind that what ever type of fan you may use, there will be parasitic loss of horse power from the engine; superchargers through the belt drive and electric fans through loading the alternator. Not with the jet engine though; you would just need an auxiliary fuel tank. Just think thrust to turbine weight ratio of 10:1. Do It!
Discussion Starter #30
So much heat though... plus, it seems like cheating.
Discussion Starter #32
Discussion Starter #33
Actually, it has been tried. I believe one of the $2000 Challenge winners of Grassroots Motorsports used a tank exhaust blower from a scrapyard/surplusto create downforce:
Actually I've seen this brought up in the Lemons forums. The casters really get me... can I really use casters to maintain the skirt, at 130 mph?
This thread is insane and I’m HERE FOR IT
I wanna see your crazy automatic downforce blower setup
Discussion Starter #35
Well, so far until I can find a supercharger to bolt up to the ac compressor slot that will provide enough downforce with the help of ground effects, or something like this, I'm changing my direction to provide high rates of cooling to the brakes by sucking air through the front of the car in a way that will transform the bottom of the car into a low pressure zone by preventing air from entering the space between the car and the ground. I'm going to aim for keeping the front of the car cool, because if I do that then my cumulative lap times get better. Maybe I can even improve the longevity of my tires.
Tie wear is a problem for front wheel drive race cars since they both propel and steer the vehicle. Rear wheel drive has a definite advantage.
Discussion Starter #37
@ddfred yup! And my whole interest and motivation here is leveling the playing field against rwd and awd.
Reactions: ddfred
Discussion Starter #38
So, I figured instead of (at the moment anyway) focusing on changing the dynamics of the way the car exits corners (although stay tuned because that'sthe first thing I'mtrying once I find a charger that can bolt up), I could just try to keep the thing out of the pit as much as possible.
I was thinking it was to pull more air across the IC but this is way crazier lol. I’m in for updates!
21 - 40 of 78 Posts
