1 - 17 of 17 Posts
Doing my oil change today as it is that time. So I put my car up on jack stands. I pull the lower engine cover and see this. I bottomed out on my charge pipe. It must have hit hard to be that dended. Now here's the thing. This pipe is still solid. No boost leaks. No cracks that I can see without removing the pipe. The bracket attached to the engine is just fine. This is why you don't cheap out on parts. This is why quality matters. Yes you might pay a bit kroe but it's worth it. I've had this pipe on the car now for four years. The damage happened somewhere between my last oil change and now. Just remember that next time you want to save a few bucks.
Sent from another garage.
Literally just saw this on the cp-e Instagram page haha
Sent from my SM-G965U using Tapatalk
Reactions: UnfocusedST
Discussion Starter #5
Well, i dented mine all the way around with t-bolt clamps. Aluminum pipes are quite frail. Nothing to speak highly of in my book.
I've seen another brand which I will not name break and fail under less stress. As for the T-bolt clamps I've heard of those crushing all sorts of different brands pipes. That's not uncommon sadly.
TLDR: Metal being metal, nothing to see here.
understatement of the year... year is only half way over and you have won!
in terms of charge pipes... others (*COUGH* MBRP) wouldn't have held up, I have experience with this and much less of a hit and more damage done to pipe, mainly the welds breaking on the pipe mounting points. In the picture it doesn't look like any issues with the mounts.
Do I get a trophy?
Reactions: screzzy
Reactions: screzzy
I wonder if that’s why Mishimoto included worm clamps instead of T bolts with their pipes. I got T bolts to use instead but haven’t installed yet, should I still use the T bolts and just be careful not to overtighten?
Reactions: Duece McCracken
Discussion Starter #13
I personally haven't had an issue with T bolt clamps. Just don't keep wrenching down on the clamp.
It's a byproduct of keeping the wall thickness down for weight and my quest to prevent boost leaks got a bit crazy, rofl. CP-e charge pipes are still the best hard pipes in the market. Their mounting tabs,paint, couplers, and locations are top notch. I just went a bit too tight, lmao. I need titanium charge pipes. Totally worth the money, lol
Tbolt clamps > worm drive
installer that knows what he/she is doing.... PRICELESS (not really because you pay for knowledge ;) and shop time)
I have installed countless T-bolt clamps and a number of different charge pipes. I normally go for broke on them, I have never broken or damaged pipes before
I have installed depo, mbrp, cpe, several times, on several STs. Only the CP-e got dented. I switched all my t-bolts to full SS ones by HPS, and i guess i went a bit too hardcore. I try to be gentle, but managing such incredible strength is difficult at times. ;)
good to know... will keep it in mind for when I do CPE pipes
gentle giant.... hahaaha love the last part.
1 - 17 of 17 Posts
