So we are running out of 12 VDC inputs to the PCM.Just swapped in a new throttle body. Car idles fine then same thing. Limp mode right after I give it gas
First start with pulling fuse 32 (10 amp) and then test to see if 12 VDC is on the pin. If it's still there replace it and try fuse 34 (10 amp) and test again.
Let me know. Water damage is extremely difficult to trace.
