No voltage present. Continuity is also goodI couldn't accept anything for what I do here because just like my day job, I sell Crack for the image, not the money.... But I digress.
If the male pin on the BJB and isn't showing battery voltage with the ignition on, and that wite has continuity between 18 BJB & 1 APP then you should be good on that side.
The next steps are you isolate the source of system voltage.
Start with the C1035C plugged in and PCM disconnected. Test PIN 12 on the PCM connector C1381B for voltage.
It will has the same color wire as the the APP sensor. It is shows battery voltage we needed to look at the engine harness somewhere.
Let me know what you find before we more forward
