I have a 2016 Focus ST. The car has an intercooler, intake, bags, and a cobb access port stratified tune loaded.
(Note: Previous owner removed fender liners and Vents installed into the hood that are operational)
I drove the car in the rain to work, went thru a large puddle very slowly and was fine. I started the car when I went to head home and engine fault warning popped up.
Throttle was very unresponsive and check engine light popped on. I limped the car 3 minutes home.
I let anything dry for about 2-3 days and still has the same problems even after clearing codes, pops back immediately.
In neutral and parked (clutch on and off), car will not rev at all: only idle, when off the clutch and in gear. The car will accelerate extremely slowly and wont go anywhere above 4k
My guess is the ECU could've gotten went. Has anyone experienced the same problem in the past?
Codes are P0303, P0316, P0453, P061B, P6A6, and P2122
