Time 1- 1.5 hours if you have everything you need
Need some skill with wrenches
PCV side info
Green 90 elbow is 3/8 O.D located behind the intake on the engine block see pic
The Intake side CLEAN AIR goes here
With 800 miles on the engine I have very little to no oil in the intake or head intake ports!
Run your hose of choice to your catch can location dont forget hose clamps
leave you self as much hose as you can for ease of routing
re - install the intake / make sure to get all the plugs reconnected
PCV side info
