1 - 17 of 17 Posts
Hi,
Im new to the forums, i just recently purchased a 2017 ford focus st and after driving it very carefully for the first 1000 miles i finally got on it in first gear and after hard shifting into 2nd, i noticed as i released the clutch, there was a jolt and it sounded really bad, almost felt like i went over a speedbump or a bump in the road even though there was no bump. Just curious if anyone else is having this problem or if anyone has input please let me know!
Thanks!
Motor mount
The motor is rolling and hitting the firewall on hard shifts. This was common on the 13 and 14s. Not sure if they went to a softer setup on the 17s.
Reactions: Cowlynz
RMM will help. Mountune seems like a great option. Plenty of threads on the subject...
Switching into 'Sport Mode' is also helpful if you are an aggressive driver.
Normal mode has too many electronic-nannies, that hinder sporty driving.
Good Luck.
Happened all the time in my 2016 and was a huge pain any time I tried to quickly merge anywhere. Put on the Cobb RMM and it is so much better!
· Super Moderator
Motor mount
Nothing hits the firewall; CPe did a video years ago showing what is actually going on. The factory mount, even the updated eFocus mount, have bushings that are so flexible that the mount housing itself hits the chassis where it is mounted.
I've never seen that. Good to know. When we first got our cars everyone was saying firewall. I put the E-Focus mount on after 2 weeks and never had the issue again even with the EFR upgrade.
· Premium Member
I have a 13 and had the TSB done. This included all three engine mounts and clutch line (added a restricter). This kinda helped but did not eliminate it. You need a stiffer mount. I went to the Boomba and later switched to the cp-e stage 2. Now I have all three cp-e mounts and JPC clutch line and love it.
Sent from another garage.
I haven't had this issue on my 16. Try with sport mode on and don't dump the clutch.
I installed a mountune RMM + traction bar and there is no wheel hop nor banging at all. Highly recommended set up.
Wheel hop and motor mount noise. I get it when wet out and the tires spin.
1 - 17 of 17 Posts
