1 - 6 of 6 Posts
Bad news is I banged up the hatch sheetmetal on my Oxford White 2013 FST ST1. Good news is I found a Oxford White hatch from a 2015 SE locally to me. In doing some quick research it turns out 2012 - 2014 share the same hatch part number. And the 2015 lists another part number. Looking at the the two hatches the only difference I can spot is the 2015 has a back up camera.
Does anyone know if the 2015 hatch will drop into place on my 2013?
And while I'm at it can I hook the backup camera to my 2013 ST1 somehow?
Thanks!
John
Where are you located? I saw a white st hatch for sale here in miami
Thanks for the tip but I'm in southern California. Just about as far from Miami as you can get while in the lower 48. The 2015 SE hatch I located is only 30mins drive from my neighborhood.
A 15 hatch will not be a direct fit onto a 13. I know the tail lights are different so you will also need a different bumper off a 15.
but any 12-14 hatch will fit onto your car
I completely forgot about the 2015 update. Thank you!
Back to the hunt.
I know people that work at my local Ford dealership. Someone backed into my RR 14 ST and they found a wrecked SE that was RR for me. they ordered it and I picked up that fender for like $110. Did the replacement myself.
Recommended looking at junk yards that have some crashed base models or even STs.
best of luck!
1 - 6 of 6 Posts
