I certainly did for my aftermarket exhaust. The hanger that is missing is the one that is above the axle, which is the tightest spot for the exhaust. I have a 3" exhaust and have had to reposition it several times as it tends to bang the heat shield in that area.Did you guys buy the Cobb hangers or whatever that is recommended on cjponyparts since we only have three stock hangers?
This is correct. The Cobb set has all 4 hangers.I believe if you have the hangar set you can add back the missing on over the rear crossmember.
Sent from another garage.
Depends. The Cobb ones are stiff so there is next to no flex which means your exhaust will not bang up against anything.Any reason to not just go to Ford and buy another exhaust hanger for 5 bucks rather than spend $50 for the Cobbs?
