Some say dealer can flash, but they also frown upon messing with the system and swapping things outMan...those look great! I really want to do this. So the SRS light came on...does that mean the airbags don't work? Anyone get them to work after the swap?
Not 100% sure, but you might be able to solve this yourself with the FoCCCus Application and OBD-II cable. There's a thread on it I believe.Some say dealer can flash, but they also frown upon messing with the system and swapping things out
Yes, passenger occupancy sensor needs to be swapped from each car. So from my st1 seat needed to be put on the st3. So simple lmao.Ever figure out the solution to this?
Dealer wouldn't touch it, just swap sensors beneath the passenger side and it turned it right now. The sensor is coded for the car itselfNot 100% sure, but you might be able to solve this yourself with the FoCCCus Application and OBD-II cable. There's a thread on it I believe.
I already found the fix lol it's just the sensor that needs to be swapped. Takes 5 minutes lolTomorrow when i get in front of my computer, i'll check the FoCCCus app for a seat/airbag option and let you know.
Okay cool!I already found the fix lol it's just the sensor that needs to be swapped. Takes 5 minutes lol
