1 - 8 of 8 Posts
Hi guy,
Hit a deer this a.m on my way to work fml and broke the big plastic clear headlight cover on my passenger side. The bulbs all seem to be fine. Can someone help me find a replacement one please. I have a 2014 focus st3. 20171010_081044.jpg
Hi guy,
It’s part of the headlamp, your gonna have to get a whole assembly unfortunately.
Sent from my potato using Tapatalk Pro
If the back of the housing is intact, you could buy a broken headlamp (broken mounting tabs or balasts or whatever, so long as the clear glass is nice. Then you just bake them open and use the glass on your current set. Some tedious work involved, but the cheapest option.
Your best bet ^ the problem will be finding a broken headlamp that has the glass intact. Honestly you need to look for someone who has a totaled car being parted out that didn't destroy his headlamps. Good luck!
Shizzle. Where can i buy correct headlamp assembly. I wonder if it would spare me a headache to just turn in to insurance. I have comprehensive.
Probably need to plastic weld that big crack in the housing also. I could see future issue that would arise from that. I would probably pull a set of headlights off a base focus and run those till I got the ST3 lights back together. Best of luck!
Junkyard (if you get lucky) or a Ford dealer. Just checked one of the big online Ford Parts departments and they list around $1200. Place I checked is selling them for $833.
1 - 8 of 8 Posts
