Alright I got a little time tonight to compare the two throttle bodies. A little key important information. First I was holding a phone for pics in one hand and the calipers in one hand.... so the pics and measurements may not be perfect. Second please note that my throttle body has been custom bored to 60mm. Stock ST throttle body should be 57mm.
Intake manifold inlet is 2.565" - 65mm
My custom bored TB out 2.375" - 60mm
2.3 TB outlet 2.425" - 61.5mm
2.3 TB inlet 2.575" - 65mm
2.3 TB out side 2.755 - 70mm
Also please note in the pictures below that the plugs are in different locations, so the comment above about needing to extend the harness maybe true. When I get around to installing the throttle body ill see if i can find some slack in the harness or rotate the throttle body to make it work. I don't wanna have to extend the harness if I don't have to.....
Final thing needed is new bolts, the original bolts are too short...... to be continued.
